CBschnell
I have only had my car for less than a week, so I'm drawing up lists of things to fix/upgrade. The car had a replacement hose and coolant change last week before I picked it up. The coolant temp runs normally and my first drive was over 3 hours, so I would have expected to see any problems then. Anyhow I have noticed that there has been coolant on the floor after two of the last few drives. I can't see where it has come from, as I have the under-engine cover, but it pooled underneath the expansion area, so could be overflow pipe? Anyhow, I digress!
As I have lost some coolant I have an issue that I can't really tell where my coolant level is with the plastic a distinct shade of beige. The interior baffles mean you can't easily poke around, so I looked at getting new OE unit. I have a Turbo so that has a different part number (P95110602502) and OPC quoted £342 + vat!!! I can get 10% off with PCGB membership. Does the CLassic Register give a better deal? Any other recommendations welcomed.
When I get a chance I will remove the under shield and take a closer look to see where it may be coming from.
