Doesn't sound right to me.
Mine isn't a CS, but as far as I know the clutches are all the same. Mine was lighter after the clutch was changed. Although there are different pressure plates meant for a 911 (964?) which fit but are stiffer.
Are you missing the over centre spring on the pedal?
I'm not sure if there is any adjustment on the clutch itself, only on the pedal height and this is supposed to be adjusted to a set dimension given in the manual.
