The business about being restricted so as not to embarrass models higher in the hierarchy only really applies in two cases: 944 Turbo vs 911 3.2 Carrera, and the 150 hp 924S vs the 944. For something like a 2.7 or S2, where the standard mapping is conservative it is really about tolerance for various different fuels.
Assuming your normally-aspirated 2.7 is in good order, which I'm sure it is, you won't transform it beyond recognition with a chip change, but it is likely to be a little crisper. Based on what you say about having a decat and some sort of trick exhaust, you already have slightly non-standard fuelling requirements for a perfect tune.
For that reason I think you would probably benefit more from a proper custom rolling-road remap if you can afford it. Good though the Promax chipsets are, a rolling-road remap would be tailored to your specific non-standard engine installation, and whatever grade of fuel you are prepared to commit to using in future - 97 octane, 99 octane etc. That will inevitable give you a more fully optimised map than than swapping one chipset based on a standard car for another chipset based on the same premise.
All of that said, on a normally aspirated car that's running well, and assuming you intend to keep the standard old-school air flow meter, I don't think I'd bother chipping it because the gains are inevitably very small - we're talking about just a few bhp here and there. Really to modernise a normally aspirated car completely the way forward is probably a bit more radical - get rid of the AFM for a MAF and put in a complete new stand-alone engine management system. But that is a much bigger job than you may be wanting to contemplate.
