I've got a grinding sort of nose coming from the front of my car. Seems to happen at low speeds, often in traffic in town coming home. Not there at higher speeds. Its definately not worn pads/discs, however does change in sound with application of brakes....
Having jacked up the front there seems to be more play than I would expect leading me to believe its dodgy wheel bearings which are then allowing the discs to drag on the pads making the grinding noise.
just wanted to check if anyone else has come across this problem and whether the diagnosis sounds correct?
cheers
Matt
cheers
Matt
