N-rated Tyres
chrisnikitas
Hi everyone,
I was wondering where I can find an official list of Porsche approved tyres for the exact dimensions I need.
285/40/R21
315/35/R21
Thanks,
Chris.
Unfortunately, in your sizes you don’t tend to have a lot of choice in Porsche N rated Spec, Pirelli & Bridgestone are about it in a matching set. Pirelli as a rule is quieter but don’t last as long as the harder wearing Bridgestone. Also, just a reminder if you want Porsche to extend your warranty, they normally insist you have to have the correct spec tyre.
Greg.
Greg.
Exactly, that's why I am asking. At the moment it wears Pirelli P Zeros, but they are not N-rated, and the warranty demands that they are. But as you said, I am struggling to find options that fit these sizes. Hence my question - I wanted to know which exact tyres are a match, cause when I look them up I may get a tyre for the front, but they won't have a matching tyre for the rear, etc.
Chris,
Your local Porsche dealer will be able to advise you and should also be able to supply suitable N-rated tyres, although it’s best to price-match elsewhere.
On the Cayenne configurator you can see what’s available for the current cars by selecting a 21” wheel size and you’ll see a small tyre symbol in the top RH corner. Press on that for the list, although it looks as though they don’t exactly match your tyre sizes.🤔
Jeff
Chris,
Jeff
Thank you, really appreciate it. I am wondering, what would happen if I went for the slightly bigger profile? These are still Porsche approved tyres.... I need to contact the OPC, as the car came out from the factory with these weird sizes
Just a heads up both Pirelli & Bridgestone are available in both your sizes. Pirelli P-ZERO NO & Bridgestone D-Sport NO hope this info helps.
It looks as though the latest front and rear tyres for 21” wheels are 20mm narrower than those on your car Chris, although they’re the same profile, so that means their rolling diameter will be smaller, leading to a slightly over-reading speedometer [probably about 2%?].
I agree that you should have a conversation with your dealer to find a way forward.
Jeff
Chris
Have a look at Hankook. I found them on Oponeo.
I have the same sizes as you and have run them for 3 years but do have a winter set of Michelins. Hankook pretty good but can tramline a bit. Wear well and not too noisy.
They are N rated.
HTH
Brian
Chris
They are N rated.
HTH
Brian
Thanks, what's the specific model, do you remember?
Hankook produce the Ventus NO S1 Evo3 (K127) NO for the Cayenne (the important bit) means Porsche fitment.
Hope this helps.
Greg.
Apologies Chris, I should have included the full information in the first place. As I said the Hankook tyres can tramline a bit especially when getting a bit worn. Good in the rain but not great at standing water. Reasonably quiet and not quick to wear. Steer well, no real feel but accurate. Ride ok, my car has air suspension.
Brian
Brian
Thanks Brian, this is really useful given you've had real experience with them. My car has air suspension too and these tyres seems like a good (also cheaper) option to get N-rated tyres and the warranty.
Greg.
Hi. I am a new Porsche Cayenne Hybrid owner and I am having serious bother getting my head round this N rated tyre stuff. I have 285 45 R21 Front and 315 40 R21 Rear Pirelli P Zeros which are N rated. They are great on the road so far. However, I do quite a bit of fishing and shooting and am look for a set of suitable all season tyres for the when I go off road. That's where my problem starts. I can get virtually no N rated all season tyre for my sizes. Best alternative I can see is Yokohama Avid GT but it looks like they only do the rear as 315 35 R21. I can get the same on the front. My question is could I drop down to the 315 35 R21? The tyres are N rated.
I had a R/R previously and didn't have this bother.
Any advice would be very welcome.
Hi, Sorry for the late reply. I am not getting alerts for some reason. I suggest you talk to the Porsche dealership regarding this matter.
Unless your car will be visiting an OPC whilst wearing its winter / all season Non "N" tyres, I wouldn't worry.
Only (re) fit the N rated tyres when its going in for an inspection, service or warranty work
Although N rating is highly recommended it isn’t a necessity, unless as touched on the car needs to go back in for any relevant warranty work or part exchange. Click here to find out more on N rated tyres.
Alternatively, why not give your local OPC a call and ask if they currently have any good deals on winter wheel and tyre packages, you could even think about putting on a slightly smaller wheel i.e. 20 inch which should not only give you a larger choice of tyres but a much bigger sidewall resulting in a much smoother ride if and when you do go off road.
Hope this helps.
The Cayenne's usually have narrower tyres for winters than summer - check your manual for the specifics as they vary by generation and model. Doubt there are any N rated all season tyres tbh
