FAIL
Mileage23,751 miles
MOT test number5087 4512 5146
Test locationunavailable until further notice
Reason(s) for failure
- Windscreen washer provides insufficient washer liquid (8.2.3)
- Offside Rear position lamp(s) not working (1.1.A.3b)
- Offside Stop lamp not working (1.2.1b)
- Nearside Headlamp aim too high (1.8)
- Offside Headlamp aim too high and too far to the left. (1.8)
- Registration plate lamp not working (1.1.C.1d)
- Direction indicators not working (1.4.A.2c)
- Steering column top bearing excessively worn (2.1.2c)
- Drivers seat insecure (6.2.A.1)
- Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
- Offside Rear Drive shaft which forms part of the suspension coupling gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.4.G.4e)
- Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
- Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
- Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
- Offside front brake binding (3.7.B.1)Advisory notice item(s)
- Offside Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
- Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
- front and rear inner wings and floor corroded
- vehicle in poor condition
- Hi all , thinking about buying a 912 white 1967 LHD ,failed MOT in 2015 with the above problems .The car has not been used since 2012 but starts and runs .
- What would it cost to have the above work done and what is the car worth without a new mot.
Many thanks
