nicksonmsport
has anyone got a pair for sale? if not can these be bought new, and for how much and where?
many thanks
nick
many thanks
nick
ORIGINAL: chrisg
I bought a pair of these ~ 6yrs ago directly from my OPC, ISTR they cost ~ £250 for the pair.
They do work well with the refurbe Mo30 suspension on my Turbo, if however you're going down the KW or Gaz route and doing serious track work you might want to consider the weltmeister fully adjustable ones from the US through Lindsey Racing. More expensive but will give considerable roll stiffness.
Chris
Lindsey sels a 5 way adjustable 19mm and also the factory m030's ,good price too.ORIGINAL: edh
Promax have a set in stock (030's). Apparently Porsche have started delivering them again - these had been on order since 2010.....I asked Andy the new price......£450!
They aren't that much bigger than s2 or turbo arbs are they? S2 rear is 18mm I think, 030 is 19mm.
I know they are adjustable, but does anyone bother once they are setup initially?
ORIGINAL: edh
ORIGINAL: Jonny944CS
I run a 26.8mm front and a 19mm 3-way at the rear with KW v3 and an LSD.
I personally find the three different hole positions quite good at effecting small changes in balance from understeer to oversteer.
After some initial fiddling I settled on some damper settings for track use and tend to just tune the car using tyre pressures and the rear arb holes.
ORIGINAL: Catamax944
the cup bar has 2 holes if i remember right
I was wrong ,the 21mm turbo cup bar has 3 holes not 2 not 1.ORIGINAL: Big Dave
Well ive got one in the garage, and im pretty sure its only got one hole.. But it is a while since i laid eyes on it....[][
