bumperblue
Hi,
My S2 has developed an intermittent misfire/lumpy running problem.
Symptoms: Very lumpy running, no power unlikely to hold tickover though, you can catch it and power out of it sometimes. The car has been serviced in February, so new plugs and filters (the problem has occurred before and after this)
It has occurred three times from cold starting, once a while ago and now yesterday and today (though its not really cold is it!) on the return trip in the evening ran perfectly. On way to Goodwood on Sunday at speed and also various other times over the past year also at speed.
So far I have adjusted the AFM by moving the pickup position-no appreciable difference in performance was noticed, checked for air leaks and dizzy cap and rotor all look fine. I have also opened the bonnet and looked at the engine in the hope that it will magically speak to me and tell me its troubles, that hasn't worked.
I am thinking the following.
1. Engine temp sensor failing and sending duff info to engine management.
2. fuel injectors
3. Idle stabilisation valve
Anybody else had a similar problem or would like to put a suggestion. All much appreciated.
Ian
2. fuel injectors
Ian
