aholymanjones55
My first post in a while, whilst like everyone else gone quiet during this COVID-19 experience.
So I thought I would share this as where we are today,12 August 2021[they have had the car now into Day4] Porsche Reading are in now in uncharted territory.
Car went in on Monday for it 2 year service 10 days before the day since it’s last major service in 2019. I had another 5k to go but the biannual option won the day. Brake pad warning light had come on a week before. Car was registered March 2016 now with 47k on the Clock.
Extras include wiper blades, clean out sunroof and fuel filler pipes, new rear brake pads and two new front tyres. Oh and refresh A/c. Tyres were the originals and was going to replace pre winter but there offer made since to cover off all together. Backs bedding changing at Christmas after a piece of flint cut into the tyre at 3.3mm.
Then came the rub, at idle engineer picked up something not quite right. Brain had an error code on cylinder 4. The resolution was do a spark plug switch to isolate if the sparkplug at fault. It was not. That meant a new fuel injector £1,800. There was one further step that does not warrant commentary. Nobody ever heard of a failure at this mileage but would be ordered in and then we would be good to go.
Further the engineer found oil in head of Cylinder4 from a failed gasket. The two incidents are not related. This would require fixing once Porsche Uk is made aware and to see what goodwill offer is forthcoming. Photos taken such a report can be submitted. This is very expensive. When I know how this pans out I will share. This is the sixth Porsche in 22 years of ownership and never taken the extended warranty always self insured….
Yesterday new injector arrives and gets fitted. It does not fix the error code.
Hence now in uncharted territory. Nobody ever seen this before. It seems to be mechanical. So requires…
Next step is to take the head off. So it’s now with PUK. What a coincidence.
Keep you posted.
I’m not a betting man but given I’m off to Le Mans on Wednesday. Will it be fixed before then? GTS is the drive to and from Le Mans….
I got a courtesy car last night after I explained I could manage without the car for a couple of days but now expected a car as is normal because I never expected a saga and fitted the maintenance around Porsche’s work cycle and lack of spare cars at the moment. So at least that’s a positive here.
Keep you posted.
