nicksonmsport
a load of bits i have left over from s2 i broke and parts removed from the 944 turbo track car. the workshop is getting to cluttered, and breaking cars is not my usual buisness so would like to clear it all out. all parts at sensible prices to clear, and the funds can be put toward something more productive such as getting the turbo track project finished!!
i can post pretty much anything, but not really into bumpers/bonnets etc, anything that fits on a pallet is fine. anything that fits into a std sort of cardbox box and weighs under 20kg i can post for around £10, light stuff can go royal mail for under a fiver usually (under 2kg) can price on application. please dont pm me here as inbox fills far to quickly.
email enquirys to info@nicksonmotorsport.co.uk
anti rollbars front 24mm rear 14mm £10 each
anti rollbar 16mm rear £20
full aperture seal set £20
complete engine loom £30
suspension cross member £10
s2 cambelt covers front and rear, complete £20
engine heat shields £5
injectors on rail with regs £60
engine mount castings pair £10
idle stepper valve/pipes £15
exhaust manifold £30
flywheel/clutch cover £30
turbo bumper stonechipped, black £25
grey bonnet good condition £25
complete passenger rear 1/4 panel (repair section) £100
s2 pistons and rods £150 (crank sold)
sunroof panel, grey £25
cobalt blue rear 1/4 trim panels to suit 10 speaker setup vgc £30
black centre console £10
rear valence, s2, grey, wants painting 2 mounts need new inserts £30
wheels nuts including lock nut key, (only 2 lock nuts available) rest of wheel nuts included £10
black headlining trim front £10 vgc
air con pump £25
fog light looms pair £10
ally jack £25
tool kit £20
bonnet hinges pair £30
sunroof electric board/motor/relays etc £30
pair of electric mirrors, loom cut to remove, will need connectors to attach to your loom or soldering (no plug in connector as std) £40
regulators £15 each
turbo carbon cannister £10
turbo fuel purge valves pair £20
washer bottle £10
s2 header tank £15
central lock solenoids pair £15
dash end closing plates pair £5
cobalt blue steering wheel centre vgc £15
boot open switch £10
grey fuel filler flap £10
interior door handle trims pair (trim that sits behind the handles) £5
spare wheel bolt/securing plate £10
pair sunvisors black vgc £15
indicator stalk with cruise control complete set £15
dash clock plastic surround, centre vents, black £10
complete seatbelt set front/rear £50
s2 radiator £40
rad fans £20
rear discs pair good usable condition, slightly rusty £30 pair
coilpack £15
alternator £30
abs sensors £20 each
heater motor complete £30
wiper motor with arms £25
pair of good s2 lower front wishbones £100
power steering pump £50
tensioner rods pair £15
front window glass £15 each
rear window glass with seals £15 each
abs pump £100
944 turbo is now pretty much stripped, engine is out, only thing left on the car is the gearbox and rear suspension setup. so anything you require from a turbo give me a shout as most is available off the shelf ready to dispatch now.
will add a list soon
all prices are open to offers so please dont be afraid to make a sensible offer on items, can do a discount on multiple items, and will only charge cost on postage.
please EMAIL requests rather than pm (info@nicksonmotorsport.co.uk)
want all these items gone asap, need the space !
hope its ok to post in this section, thought it would be more suitable as all 944 parts.
many thanks
nick
air con pump £25
ally jack £25
tool kit £20
regulators £15 each
washer bottle £10
s2 header tank £15
s2 radiator £40
rad fans £20
coilpack £15
alternator £30
abs pump £100
many thanks
nick
