M030
TTM
Well-known member
What car do you have? M030 contents will vary with model and year of production.
The option code 'M030' on the sticker on the first page of the service book, or on the sticker inside the load area, between the rear lamps, will provide confirmation.
Thanks for almost instant responses! It's a 1991 S2. doesn't have the option code in the service book/sticker, but I wonder if it's been upgraded. Was advertised as having lowered suspension but I can find no evidence in receipts/history. chris
90/91 S2 with M030 should have the same 7.5" front and 9" rear D90 wheels and brakes as the 90/91 turbo. Check for wheel width and offset around the valve.
You've probably just got some lowering springs fitted. M030 struts are yellow, made by Koni and have an adjustable lower spring perch so you can raise/lower the ride height. They also have a plastic tab at the top of the strut to adjust the rebound. Pictures here: http://dsims.myzen.co.uk/944t/suspension.htm
