Update - well all assembled again, new pump, new pump-radiator hose (mine was a bit swollen), swapped in a new seal on the bottom balance shaft (which seemed to have a persistent oil leak) and one new tensioning sprocket (for balance belt). All other seals looked OK. Oddly I had ordered a new cambelt but this was a good inch too long to fit - i.e. even when installed and the tensioner at maximum - it would not fit , so had to reuse the older belt for now. I;m wondering if I got an 'S' belt in error - are these a bit longer? ALl back together - coolant added - had one drip from the pump take off hose that I fixed with a new O ring seal. And this leads me to a question - on the pump I removed, this take off was blanked off, yet on the 2.7 pump I received, this was a functional feed. To me it makes more sense to have this open than not (and why provide a hose for it otherwise?). Both pumps had 2.7 stamped on them, although the new one seemed to have a later version number next to it...? Car fired up OK and ran without undue noise or apparent leak. I lessened the tension a bit on the balance belt to remove the whine I had before- and it sounds better now. Will take for a drive later to make sure all is actually well....! thanks ian
