LSD
Hi All,
I am looking for a 968CS but ideally after an LSD. Since this only came with the M030, can one be retro-fitted since most cars don't have the factoru M030 pack?
Also any ideas as to the cost?
You're probably better just buying an LSD from an aftermarket supplier such as Quaiffe. The original Porsche LSD is pretty rudamentary and slackens off fairly quickly so any 2nd hand unit you get will most likely need a rebuild, so by the time you take into account the cost of a rebuild you are definately better off going the aftermarket route.
Not all M030 cars came with LSD,s, it was a option...
But to answer your question. YES you can fit a aftermarket LSD,, Quaiffe, Guards, Carbonetic [ 9M], oem lsd [ used]...
I think the cost will be around £1000.. But that all depends where you get the diff from. + fitting costs....
There are 2 types of diff. The torsen or torque sensing, and the plate or clutch type...
The "torsen" type diff isnt as prone to wear as the "plate" diff. The "torsen" is also a quieter diff , as the "plate " diff can be "grabby" at times...
Hope that helps you....
