Not sure what the problem is
Near Side (LEFT) Main beam headlight not working
Checked the Fuse - OK
Replaced the Bulb
I think its the connector as the Indicator did not work till I removed the Light Unit and put it back
Am I right in saying the connector is the one that is fixed to the Body
Any other Ideas please
Will try WD40 or a connection cleaner
The unit has a separate connector that unclips and another that is fixed to the body at the back of the light unit
It does not seem to be fixed properly and may move back when the light unit is refitted
There are two yellow clips and I am not sure how these are removed to unclip the connector from the body?
Replaced the Bulb
