Lifting with Quickjacks.
blade7
Well-known member
I assumed the rubber blocks should be placed under the factory lift points, just behind the front wheels, and the square lift points just in front of the rear wheels. I know a couple of members on here have quickjacks, so is that correct?
Yes - shorter rubber blocks under the front “doughnut” points that you’re told not to use a regular jack on and the rear uses the rectangular-ish points with the thicker rubber blocks.
I had to use a large and small rubber block to clear the sill trims at the front, and a single large block at the rear. Lifting was a lot less hassle than using a jack and 4 axle stands though.
