nick9one1
After the downpour we've been experiencing here over the last few days I've discovered a few leaks!
I've got a very very wet offside rear footwell, and a pool in both boot cubbyholes.
I think both rear hatch pin lock seals are leaking... water running over the rear light plastic covers. (£20 a side!!)
The drivers rear sunroof pipe just seems to dangle in the boot cubby hole and is too big to fit through.
The front plastic shelding under the wipers is all cracked (I've heard this can cause leaks?!).
The rear hatch is "de-bonding" from the sealent at the top corners.
So far I've blown down the rear sunroof pipes with an airline - no blockages anymore! I couldnt see the fronts in the dark. Do I need to remove the sunroof to access them?
Iive also used the airline down the short tubes from the rear hatch pins, and those are clear .
Any other suggestions for the leaks?
