Kumo tyres
- Thread starter berg944
John Maddox
Probably in back to back test with mainstream tyres they would compare badly but grip seems ok and they last well.
Porsche centres always remind me they are not porsche approved - you pays yer money and makes your choice !!
I was pretty cheesed off generaly after I had spotted his spotty oik about the try and lift the car with a trolley jack under the transaxel [
As the tyres are now on, cheap and legal (and I don't want people who indulge in personal pleasure getting near my car again) I have decided to leave them on for the winter. The supplier has offered to change them for a known brand at the cost difference in fairness to them.
The tread blocks are so tall that the tyres must get squirmy when hot, but they give more grip then my old, almost bald, Contis in the wet. The plus side now is that any wheel spin can be enjoyed all the more as I know that I am dispossing of a naff set of tyres.
ORIGINAL: John Sims
I was pretty cheesed off generaly after I had spotted his spotty oik about the try and lift the car with a trolley jack under the transaxel [] but stopped him befor he wrecked it.
Thats how the garage i use lift the car (unless they are using there hydralic lift.)
Well it's not a Porsche prescribed jacking point.
In the good old days of Ford live axels I wouldn't have an issue with lifting an Escort on the diff housing. Now, with independent rear suspension and the 944 transaxel, I wouldn't risk it myself. The diff housing/transaxel isn't a load bearing ellement when the car is on its wheels so why would it be designed to support 50% of the weight of the car for jacking purposes.
If jacking on the transaxel doesn't break it then I'm sure it is only by luck not design.
I ended up having an argument with Micheldever Tyres once when they wanted to Jack my 944 up by the trollyjack under the transaxle method...[
It specifically says in the handbook not to jack it by the transaxle if I recall.
Page 89 in bold:-
"The vehicle should never, under any circumstances, be jacked up from under the oil sump or gearbox, as this could cause severe damage."
Well, that about sums it up then.
Diver944
ORIGINAL: berg944
Anybody on these?
Only £60 (245/45R 16W) each, but will they grip in the wet?
Berg I've been on the Z rated Kumho Ecsta 712's in that size since the summer. They were £75 inc fully fitted and I'm very happy after about 5000 miles including a trip to the Nurburgring. Wet or dry they seem fine to me on the road, and they don't spin under the conditions you describe. I've only used them on track at the Nurburgring and they got a bit squealy and squirelly after 3 laps (12 miles a lap IIRC)
