Knife edging
mushtykev
Following on from my earlier post ....http://www.porscheclubgbforum.com/tm.asp?m=755259&mpage=1&key=&#755259
My engine is now out to have bores honed, new rings/big end bearings etc etc
My crank and flywheel have now gone to be lightened and balanced but wondered if these cranks can be "knife edged"to help combat the windage issue when running at high rpm's.
Planning to track the car so wondered if people had had this done and if it helps, or if they fitted a crank scraper from the US?
Cant seem to find anyone in this country who does the scrapers so thought if it is effective to have the crank edged i could get it done this week also.
Cheers.
Yer tell me about it! ha
Is there anyone here who tracks their car without a scraper?
Be interested to know if they have ever had any oil pressure problems?
Had the crank on my 1964 mini cooper knife edged, and it revs so freely I was worried about over doing it, so fitted a rev limiter....
I think I probably wasted my money. Unless you're looking for the ultimate and prepared to rebuild the engine every year, in which case go for it!
Id be looking at trying to lighten it and then balance it back up. Porsche cranks are very well balanced but weight is always a compromise in a road car, so therell be some meat to come off. What sort of redline are you proposing? I believe that 7,000 is achievable.
Yeah, this is the issue. I think knife edging will be too extreme for me as i really am aiming for a road car that i can take to the odd track day.
As mentioned, both the crank and flywheel will be lightened and balanced just to help the engine rev more freely and allow the revs to drop quicker, but now i see these engines suffer with this windage issue i just wanted to avoid regular strip downs and rebuilds.
I would have thought you'd gain as much by having the engine blueprinted:
Rods balanced to all the same weight
Pistons balanced to all the same weight
Crank, flywheel and Clutch mechanism dynamically balanced
Yours
Chris
