JCR exhaust to a 718 GTS 4.0?
No, but I've been running a replacement silencer on my 718 GT4 since almost new on road and track (for 24k+ miles).
My advice? Don't bother. Any silencer, from any brand, is not worth the cost as there are no real improvements to be had in either power or sound. Anything more than a silencer and you're into remaps etc so bye-bye drivetrain warranty. Ever. Porsche will know the car was remapped as the ECU logs a LOT of data.
If you have a manual gearbox, I would totally recommend spending the money on a single mass lightweight flywheel instead. Worth every penny, and much less than an exhaust!
Otherwise, leave well enough alone....
Have you considered implementing the cheap exhaust modification. Prevent the exhaust valves from opening, either by removing the vacuum lines and putting a grub screw in the end, or putting a collar on to the valve stems, thereby stopping them fully closing.
100% fully open valves, all the time, will induce drone. Just so you're aware.
The valve collar mod is a good one if you want to experiment - cheap to do too if you don't mind crawling around under the car (y)
