Injector Service Kit
gajh
Hi All,
I am about to fit service kits to the injectors. The question I have is the end cap (looks like a top hat) are they just a push on fit?
Gavin
Hi Rob,
This is the seal kit that I have to fit on the injectors is the hat just a push fit
Yes its a push fit.
You don't seem to have the little brass coloured filter to go with the kit. These are also a push fit, I replaced mine because they were in the kit I bought , but the ones I pulled out looked clean anyway. They are a pain to remove.
As vince says
definitely push fit but use a flat surface as they are quite easy to break.
Thanks elliot, so I can press on the end of the injector with the cap on, I wasn't sure if I had to put the cap in a hole and then press the injector in so as not to damage the tip of the injector.
regards
Gavin
