I can't throw any more money/time at this idle problem so I'm putting it out to you boys.
Starts fine when cold and will idle at 950rpm until you drive away then idle will nearly die then picks up. High revs are needed to drive due to hesitate and odd low revs until it's warmed up. Rarely when you put the clutch in from high revs the engine will almost die but then pick up.(warm)
New cap, rotor, leads and plugs.
What I have done
AFm checked as shown on Clarks garage
tps checked at dme plug and is correctly set at throttle body
no vacuum leaks
Engine temp sensor is within tolerance over temp range
icv is free of grim and rotates back and forth freely, it has a 12 volt supply
any help welcome
What I have done
no vacuum leaks
any help welcome
