hazel.david
If you get a stain on your leather jacket, then you need to act quickly to make sure that it does not damage your leather jacket and stays for longer. So, you can start by gently cleaning your aviator jacket mens with a soft and damp cloth and rubbing it against the stain. For more tough stains, you can use a leather cleaner that is made specially to clean real leather. Avoid using harsh chemicals on your jacket, and do not soak it in water or bleach. If your jacket is stained with oil or grease. Then you need to sprinkle cornstarch or talcum powder and let it sit overnight before brushing it off.
