nickbartleet
I'm just restoring a 944... this is it at the moment:
https://www.dropbox.com/s/mflcywggxo7vnlx/IMG_8504.JPG?dl=0
And starting to work through the niggles... lots of them... first is leaks. Sill have all been replaced but just did a hose pipe test and i can see the run marks through the door jam vent holes, where the water has run down into the sills. You can see it is dripping from above and running down the inner wheel tubs.
https://www.dropbox.com/s/qwgs4yg7jsbsuh9/IMG_8652.JPG?dl=0
https://www.dropbox.com/s/rtvbfp235vg4b9s/IMG_8653.JPG?dl=0
https://www.dropbox.com/s/il4ngbqwmd1gcgi/IMG_8654.JPG?dl=0
https://www.dropbox.com/s/5tnh6o29fmsxjwi/IMG_8655.JPG?dl=0
The one side could be from a hole behind the filler cap... is this supposed to be left exposed like this, but doesn't explain this happening on both sides:
https://www.dropbox.com/s/m6l01nqkw6p1pdf/IMG_8651.JPG?dl=0
I have just replaced the sunroof seal, and cleared and checked the sunroof drain hoses are working... they were not, but are now. Any ideas would be super helpful.
