So, have mentioned this before but it is still happening, car starts and runs fine from cold but once warm it starts but wont rev, the rev counter is all over the place, I turn it off and on again and that seems to help, it clears and runs as normal, well as normal as 944s get !
I have changed
Fuel Pressure Regulator - New
DME Relay - New
Air Flow thingy - Second hand
Lambda Probe - New
Battery - New a year ago
So, what should I try next,
My list of possibles, in no particular order
Temp Sensor - Removed and tested it, seemed ok in a pan of water.
Speed Sensor - not sure how this could be related
Crank Sensor - Ok when cold so dont expect it is this
Injectors - Possible but if they are leaking wouldnt it be worse the longer it is left ?
Earths - Again, ok when warm
Fuel damper - Removed vac line, slight whiff of fuel, do these cause this issue
Fuel pump - Ok when cold
Dizzy cap, just went to change it for the spare but it didnt have the pring loaded bit on the top
Rotor Arm ?
Plug Leads ?
Plugs (Removed, checked gaps, seem ok, might change them anyway)
Ignotion Switch - I know they can be a pain in the arse
Coil - Possible I suppose, they do go iffy when hot
DME itself
Fuel filter, cant get it off as stuck to pipe from tank.
Ignition control thing in inner wing on right.
Dont want to put it into a specialist, apart form getting expensive I want to learn from it, but it is so embarassing when it spazzes out in a car park !
I have changed
DME Relay - New
Lambda Probe - New
Rotor Arm ?
Plug Leads ?
DME itself
