Hot rubber smell from air intakes
keith.shepherd
Hi guys. I have a 2015 Boxster S 981 and during my 12 month ownership I’ve noticed quite a strong a hot rubber smell coming from the air intake. This is when getting out after a long run and also while standing, say at traffic lights with the roof down. Is this common and normal for the car? It runs fine, is low mileage and still under Porsche warranty. Ive mentioned it to the local OPC but, as it usually goes, the smell wasn't so strong while I was there. The dealership reply was that if the car is running fine, and you have no warning lights on then not to worry. I know the engines must get pretty hot in their enclosure.
I'm taking the car in to the OPC for its two year inspection shortly and would like to ask if there is anything I should ask the service technicians to check out?
Thanks for any help anyone can offer.
If it helps, my 2009 / 2.9 987.2 at 90K miles now did this as you describe when 34K miles old 9 years ago.
Everything works well.
I rather think "They all do that Sir" is valid.
As the OPC said, no lights, running fine, keep on driving.
Just my 2 pence.
My 2.7 981 did this but my 981 GTS doesn’t. No warning lights or any observations then OPC comment is correct. 👍
My 986, 987 and 2 x 981 all did it sometimes. In 183,000 miles never worked out why only sometimes. Nothing to worry about IMHO.
Hi Keith,
I’ve never noticed this on my 987.2 CS, but it has a different arrangement from that of the 981 which has separate ducts on each side of the car with each duct split into two paths: one for intake air and the other for engine bay cooling. On the 987 the left hand duct is for intake air and the right hand duct is for engine bay cooling. I assume you get the same smell from each duct?
The main source of rubber will be the rear tyres and when you’re stationary the fan will draw-in warm air from them, but I can’t believe they’ll get hot enough to give off a burning smell, so you’d have to think that the source would have to be engine-related; but there again only the exhaust system will get hot enough to burn rubber and you’d expect to experience a failure of some type due to a rubber component touching the exhaust. Very puzzling!🤔
As others with experience of the issue have said, nothing to worry about.
Jeff
Both this and previous 987.2 did it. I think it’s the belt that smells - almost like a clutch burn smell.
doesn’t do it often. Did it more after a service where the belt was changed and I think in my case I smell it more when I put it away straight after a drive and especially when the engine compartment fan kicks in.
It’s one of my standard responses to new boxster / cayman owners along with “yes the steering will feel heavier than you are used to, the brakes need to pressed harder than a “daily” and it makes noises and smells you won’t be used to because the engine is right near your head - especially as you get out of the car”
I agree with “they all do that “ in this case.
Thank you all for your replies. It's interesting and reassuring to know it's not uncommon. I did go on an East Sussex club run before and wanted to go round sniffing other Boxster's air outlets, but I thought I might look a bit odd, ha ha.
For Jef's reply, I haven't checked the passenger side and will do. It's not so much a burning rubber smell which is quite pungent, but hot rubber, and stronger after a hearty drive.
Thanks again for all your comments. I'll ask the OPC what component they think it might be. I was assuming it would be a hose from the cooling system.
Honestly don’t be surprised if OPC tell you “nothing wrong”
If it worries you, pick a local well recommended Indy and ask them. They don’t have a dog in the fight.
Keith, like the others, I suspect the rubber smell is normal. I have a 2010 987.2 Cayman S (basically the same power unit as the 981). On the 981, engine bay ventilation is improved over the 987 with cooling ducts both sides. When I acquired my 987 in 2015, at 48K miles, I had the same hot rubber smell after long runs. Mine is garaged, so a confined space, meaning the smell was contained and quite pronounced. After 10 years (and now 94K) it has not led to any problems and either I don't notice it any more or it doesn't smell so strongly.
There is another thread on this subject, https://www.porscheclubgb.com/forum/threads/they-all-do-that-sir.216806/#post-1324511. In my response to that one, I mentioned a potential issue with belt tensioners seizing. I now know of a second 981 locally that suffered this misfortune, leading to a sheared bolt on the tensioner mounting arm, see image below. The sheared end on the engine is in the centre of the picture. To the right is the tensioner arm, with the bolt head and threads exposed. It cannot fall out completely because it will contact the cover panel on the bulkhead. Below these the darker object is the hydraulic tensioner/damper. The lower mounting bolt of the tensioner/damper is also visible but very difficult to access. with the engine in situ
The OPC will tell you that replacing the hydraulic tensioner/damper and removing the remnants of a broken bolt is an engine out job on a 981, so worth checking that the arm moves freely to avoid that major work. By removing the trim and metal cover panel on the bulkhead behind the seats, you can check for free movement of the arm, and any oil seepage from the hydraulic damper, .
On my 987, I experienced a partial seizure of the tensioner arm, which I caught during a service (after taking the tension off the belt, on releasing, it did not return back against the belt). There was a lot of rubber dust around the hydraulic tensioner, which had been seeping fluid so I replaced this as well.
