Thanks Stuart. I do trawl the web for answers and solutions before putting stuff on here - honest guv! However it's not always easy to find with the different year models and lack of pictures. Per your suggestion with the check valve, where does it connect to? All the diagrams I have looked at points it to the brake servo, but I can't see anything there. Interestingly under the brake reservoir there are two pipe connections, and in pictures I see brake lines coming off both those but on mine, one nearest to the firewall is just closed off. I'm just using these as examples of trying to find the right information, and whether my car is standard or modified, and if modified, to what and for what reason. I have been going to Clark's Garage and Pelican for info as well as forum searches, but if there are better resources, please recommend them to me. Anyhow I do appreciate the wealth of knowledge on here and people sharing it.
Back to the matter at hand, although I have thick binder of receipts, there doesn't appear to be anything regarding mods. FYI the cycling valve is there. Your and David's comments got me thinking, so I explored the DME... Well it doesn't have the metal bracket behind the wooden floor piece, and it is definitely not a Bosch unit! The black box is nondescript with a couple of numbers but no manufacturer's name. Of even more concern, the unit is hardwired! Do any of your recognise the type of unit?
[attachImg]https://www.porscheclubgb.com/forum/download.axd?file=0;1130407&where=message&f=IMG_5742.JPG[/attachImg]
Thanks in advance,
Chris
