Hope someone out there might be able to help me.
I have a 944 turbo 91, and it seems to develop a massive misfire / boost cut when hot and you get to the high rev range. It makes boost fine when cold and warm but after a few miles of hard driving startS to mis fire and cut out after 4000 rpm. seems like the boost is cutting out as it produces loads of black smoke as if it is over fueling.
my diagnosis was a boost leak or faulty temp sender but i have just done a boost test and it holds 1 bar pressure pretty well. (slowly leaks down to 0 but it takes a good few minutes to leak out and i can't hear any obvious leaks.)
i noticed though that the vacum pipe that goes from the bottom of the throttle body to the temprature valve at the back of the engine is missing. it seems the temp valve should have 2 pipes connected to it and the one to the throttle sensor has been snapped off at some point so i will have to buy a new valve to connect it. i don't suppose this is likely to be my problem but i had a new hybrid turbo fitted and then sent for a remap just before the problem started. I was wondering if it has been remapped with this vacum not connected whether this could be my problem?
i will also change the blue engine temp at the front as well as the valve to rule them both out.
any thoughts would be welcome
