derekboone
hi all, happy Easter!
I Love my new to me 977.1 C2S, but a strange occurrence is haunting my enjoyment!
on three occasions I have accidentally hit the Rev limiter as I go up the gears from second to third- usually I push the clutch in a second to early!
i know- very amateur!
Each time, the engine will no longer idle.
it drives and pulls fine, but cuts out as you pull up, at traffic lights, a roundabout- or wherever. It always re starts, just will not idle.
when the engine is cold, the fault disappears. When you unplug the MAF, the fault disappears.
So the quick and easy thing to do is replace the MAF which I have now done three times! It cures the fault but Why does the car do this? I’m guessing it is an electrical fault? Will a re map cure this for good?
it feels like the cars tells me off each time I spank it!
