eddieedmo
vac pipe sounds loke the breather from the oil filler spout , if smoke not coolant , have you disturbed the power steering fluid resevoir pipes ? could be running onto exhaust manifold , maybe just oil on manifold following rebuild , will burn off after a few minutes , if not a leak somewhere. Nick [
