dirtydirtyharry
Hi,
Could I run this problem past you all please.
I parked up at work today as usual. When I got back to the car at the end of the day my battery was flat. It wouldn't fire up. I could hear a clicking noise coming from the fuse box. I removed a few relays one at a time and noticed that the clicking stopped when I removed the cooling fan relay (part no 944 615 105 01).
I managed to get a jump start and then put the relay back in (causing the fan to run permanently now) and drove home. Ive left the car on the drive minus the relay (as it will presumably keep the fan running all night and the battery will again be flat in the morning.
Will it simply be a case that the relay has failed and I need to source another?
There is one on ebay for £30 which seems a bit steep to me.
Is it possible to fix them?
Cheers for any help.
