Can anyone tell me where the thermo switch is for cold start injector.
At the moment there is no positive feed to the cold start injector just 2 negatives - can't be right can it?
Also can anyone confirm if the fuel pump relay has anything to do with the cold start injector?
Awful starting problems just now. Cold start it's like a cylinder is missing, then warm start it turn over and over without actually firing - hopefully the same problem will fix both!
All help much appreciated.
Andy
And please note, I am a registered member despite it saying otherwise. Membership no. 43818.
Gold/champagne 924, A183 HWD, if anyone has any history on the car, be great to hear from you.
Replaced rear seal, that went on fine, but the sunroof seal, while it fitted fine, the roof doesn't seem to settle completely flush now, is that going to cause me problems or is it just because the seal is new?
Andy
![Spanner 5 [sm=spanner5.gif] [sm=spanner5.gif]](/forum/styles/default/pcgb/spanner5.gif)
