height ride with 18"
Konstantin
I everybody, I am riding front tyre 225/40 on 18" rims (back 265/30) ;is the RS ride height ok with 1 degre of camber(as RS setting I suppose) or will it touch the arches .964 C4
many thanks for your help Konstantin
You need to consider the ET of the wheels you are fitting as to whether you will touch the arches or need spacers, not all 18" wheels are the same.
Hi again ,the back is sorded (with spacer anyway) but the front is the probleme the rims are speedline original split rim I would like to see it as low as RS spec is it possible or it is going to touch the arches?
thanks Konstantin
Again check the ET but generally they should bolt straight on. No spacers needed.
What spacers did you use on the rears and what width are the wheels?
Think that maybe what he's getting at. The straight fit may not be on a C4 although I have plenty on clearance.
