heater control unit
aporschefan
Hi all, where is the best place to buy a second hand heater control unit?
I need one for my '91 944t and have air con that works...
I had a look on ebay. There are 2 available but none of them explicitly have said those units will work with air con. Are there any decent breakers?
Speak to Elliot forum name "elliot" he will probably be able to help you out. Are you absolutely sure the CCU is broken?
Thanks rob. I'll look up elliot.
The unit in the car works 100%. I need another one so I can change the bulbs in the unit to LEDs. I'm not an electronic engineer so someone is helping with the electronics. I wanted to source another unit so if all doesn't go according to plan, the original unit is available for use.
