Heat
Ash944
It's very hot but I can't get cold air
Iv looked at the heater unit and the slider that operates cold air flow isn't connected properly and the little bar is all bent Iv not hand chance to look yet but Iv read that if you take out glove box that metal rod should run up behind could I simply pull/push it to get cold air or could it be something else
Ash
I'm sure one of the boys on here will be able to point you in the direction of a pictoral thread using the search system.
Simple answer is there is a 99p plastic clip thing that holds the metal bar onto the adjuster flap, once this breaks the system default is full hot air - winters in German can be quite cold !
In order to access this you'll need to remove the glove box lid and liner and look down to the right from the inside the glove box.
If you get stuck look up this document HVAC-01, 944 HVAC Opeation and Malfunction - this details the issue:
"Full Heat at All Temperature Settings (1985.5 and Newer 944s)
On late model 944s (1985.5 and newer), there are several problems that can cause the full heat condition. The first and most common problem is a damper linkage in the driver's side footwell (for left-hand drive cars). Stick your head in the footwell and look up and toward the center console. You should see a small diameter metal rod which rests in a white plastic support and is held in place by a metal retaining clip. On later model 944s, there are two damper linkages instead of one and they are located behind a plastic cover. One of the plastic clips on the linkage may be broken preventing the linkage from operating the damper. When the damper fails to operate, the system fails to full heat. Most German cars are designed to fail this way. It's a safety feature to keep you from freezing in winter. The first picture below shows a linkage that has come loose from the support because the metal clip is broken. The second picture show the linkage properly in place with a new support and clip along with the part numbers for the support and clip
at www.clarks-garage.com
Yours
Chris
Chris, Ive only skimmed but surely this is for a series one car, as opposed to the series two which has a vacuum controlled H&V system?
Equally rushed search for a helpful link! [:D]
http://944foot2thefloor.blogspot.co.uk/2009/09/how-to-repair-heater-control-valve-on.html
that is a brilliant write up
the controls are very simple on a s1 car but replacing a bowden cable is a pain. I found it very fiddly to reconnect to the slider.
Mine is either full cold or full hot, depending on where I set the temperature dial to. I'd love a bit of variation between the 2 extremes! I expect I'll be dismantling the glove box to take a look at the weekend
Where is the best place to get the white plastic clips from, one of mine has snapped thus causing the heat to be on full.
Are they not still available new from OPC's for not alot of money ?
Indeed. The plastic clip and metal circlip are under a pound new for both. Why on earth would you use a second-hand one? [8|]
Iv not had much time since becoming a dad on Saturday.
But I did get out today for a hour the heater control vavle is knackerd I think
It doesn't move at all.
Iv had a quick search but what one do I need
Iv not had chance yet. But if the weathers ok this morning I'm all over it the wicked Witch of the west is round this morning.
ORIGINAL: Ash944
Congrats on becoming a Dad.
I don't have any experience of the square dash heating system sorry!
