bmnelsc
I have a '91 S2 with the adjustable headlights - the three position dial switch on the console. My dial spins pretty freely with no noticeable detents or "stops" when getting to position 0, 1 or 2 (other than hitting the end of travel). Is this normal or should there be a "stop" at each dial position? Basically, it feels like there is no contact in the potentiometer.
My headlights don't respond to the switch anymore (used to but somewhat intermittent) so I'm trying to figure out how its supposed to behave before starting diagnosis (checking power at the connector, etc).
Also - I assume the headlight adjusting motors can be lubed with electrical switch cleaner/lube with no ill effects? (The spray you used to use on your stereo's volume and balance controls when the crackly noises weren't down to the LP) .
Thanks in advance.
Thanks in advance.
