hard cornering rumble
dave364634
when i come off the motorway onto a long left at speed, i get a bearing like rumble.
is this likely to be the transaxle, or something else?
at low speeds its not a problem, so if its not a common problem i'll let it develop.
ta. :)
I'm no expert on these things but I'd agree with rcsalmons - most likely to be a wheel bearing rear right that's being loaded through left hand corners. I believe that relatively speaking the driveshafts and CV joints don't get much load through cornering ?
Could also be front wheel bearing - and it's a bit frustrating tracking it down to that when you've already gone to the expense of getting the rears done...
I had a front gone - and the noise seemed like it came from the back - definitely didn't feel it through the wheel Took a lot of tracking down - Promax solved the problem eventually
