Chaps,
My S2 has developed a grinding noise from the back. It's on the left hand side of the car, and only occurs when going 'round a right-hand bend (i.e. when the left hand side is loaded up). It's related to road speed and is a constant noise - as opposed to a clunking or ticking noise. The tyres and wheels are standard (D90's) and the suspension isn't lowered.
I've had the rear wheels and brakes off and can't see anything that looks polished or rubbed. Has anyone else had experience of this sort of thing and, if so, what caused it?
I'm suspicious of the handbrake shoes as they are badly worn (pretty much worn out) but driving along with the handbrake on doesn't cause the noise to happen. Another possible culprit would be a rear wheel bearing (although the one on that side was changed about 60,000 miles ago and the noise isn't the constant droning which I associate with a wheel bearing).
Any suggestions from the more knowledgeable chaps on here will be welcomed - thanks.
