EddySpaghetti
Hi,
I've had this leak for a while, and have just kept topping up to avoid wear. It isn't very significant, but is annoying.
The leak is where the cooler pipe is 'plugged in' to the gearbox at the front / bottom, in a transverse direction.
I had a garage inspect it when I had the clutch changed last year and he said the pipe end is corroded, preventing a good seal. Does anyone have any experience of this issue, or advice on whether some machining could tidy it up enough to seal again. The replacement cooler pipe is about £450 from OPC
Cheers,
Eddy
Cheers,
Eddy
