bmnelsc
You don't mention any difference in clutch operation - is it stiffer than before? From your description I would suspect the clutch is not fully releasing. Check the fluid for level and then the travel on the pedal, clutch and slave cylinder. The manual provides the measurements for travel on the clutch fork and provides minimum travel. Less than minimum travel indicates the clutch may not be releasing fully. If you get sufficient travel initially but it won't hold the gap then you probably have some fluid bypass in the slave or master cylinder.
