Monkeythree
With both the rear axle and the gearbox cross member off my car at present it seemed sensible to check the gear linkage above the gearbox for slop. As expected, there is a load of play so I started to remove it in anticipation of ordering a replacement from Only944.
The snag i hit was that the bolt which connects the front to rear shift rod to the linkage snapped leaving me little option but to drill it out. So my question is, are both the female part ( the end of the shift rod) and the male part (the end of the linkage) tapped? I don't want to take the shift rod out unless really necessary so first prize for me would be if the female is just a hole and only the male part is tapped. If both are tapped, I'm going to have to remove the shift rod so that I can tap a new thread.
Thanks in advance.
Thanks in advance.
