Fuel Pump
- Thread starter 944 man
924nutter
If you are fitting the 220 the S gearbox might just hold together if you don't boot it hard, but remember the turbo has hardened crown wheel and pinion so dont be surprised if in a few months you are asking for advice on changing the gear box. In addition I think the ratios will not suit the turbo engine. The S is geared to do about 144 at probably something like 6400 so your turbo engine will just get you there quicker then sit on the rev limiter. I had an S so I know the rev limit is 6800. Of course you could go up an inch on the wheels to raise the final drive ratio, but I would have thought that unless your S is particularly good (in which case why ruin it) the expense isn't worth the trouble. Driving an S is akin to driving a 190 hp turbo if there was such a thing. Foot down nothing much nothing much nothing much 3700 an off you whizz. From the look of the pic you do have big wheels but the rest of my comments are relevant, and how will you stop it. The front brakes are the same as the 924 Turbo (and early 928) even the S2 with a MERE 211 BHP and a shed load more torque has four pot calipers. I sincerely hope that my comments have been premature and that you have considered these aspects and have them covered, otherwise I am inclined to think that driving it will not be the sinecure you hope it will.ORIGINAL: gajh I am in the process of fitting a turbo engine in my S and wonder if I would have to replace the fuel pump with the one from the turbo or would the one in the S be ok. Thanks
gajh
No, all Turbos have that. What the 250 gets in addition is the standard limited slip diff.ORIGINAL: 944 man Isnt it only the 250 transaxle (whose code I forget) which had the toughened up internals: 1st, 2nd & 3rd and thicker output chafts?
924nutter
Great to see you have done your homework, should be nice fitORIGINAL: gajh Hi, Love the comments and thats why this is a great forum, I have all the turbo running gear, the torque tube, LSD gearbox and the engine, i also have the m030 brake callipers front and rear, I have an uprated turbo and LR maf conversion but wont fit this just yet. I have got a turbo and ecu and klr from nick that he has chipped so should be a good starting point. I am also running gaz gold pro coil overs oh and I also have the turbo front ARB. Before fitting I will be fitting a new clutch, timing belt, balance belt and all the runners. Yes I am running 18" Sport classic II alloys, must admit it is a comfortable ride compared to my bmw 235ci.
scam75
Well-known member
We will forgive you Simon!! You are usually anorakically spot on (if that's even a word!!) [ORIGINAL: 944 man I see that I have included the phantom hardened third gear again, despite knowing that it was only 1st & 2nd... The 016R-5P transaxle originally had a coiled oil cooler and a 40% locking LSD was an option. The oil cooler was made a cost option for 1987 and 1988.
