Hi all
After reading this excellent post, and with my MOT due in mid-June, I'd better start to think about last year's MOT advisory of corroded fuel lines. I don't want to repeat the above post and start a fuel line debate, I just have a couple of simple questions.
I am not prepared to spend the vast labour costs to have the axle dropped and an as-original, hard line installed, especially when so many people have had flexible/braided lines fitted without problem. I am also hoping to do all the work myself, and have a mechanic friend who would help out for a little monetary incentive if the going got too tough. So my first question is, is there a complete, off-the-shelf solution to replace the fuel lines from pump to regulator, or do you have to effectively make it yourself?
If it's a DIY job, can anyone point me in the direction of some suitable parts to buy? I don't want to go cheap, and I don't want to go top end. I'm after a sensible, reasonably priced solution. If metal, braided flexible pipes don't cost the earth, then that would be great, whether they just cover the joins to the pump and regulator, or run the entire length unbroken. If their cost is prohibitive, then I'd be happy with rubber fuel pipe, if it's man enough for the job.
I would also like to suggest that, if anyone has documented this job before, that it would be worthwhile having an FAQ for it, as I'm sure this is a job that a lot of people could tackle themselves.
Chris
Chris
