Frozen brake calliper bleed nipples.
- Thread starter aarndell
vitesse
In those circumstances I would soak the affected bleed nipple seating area several times with a releasing fluid such as GT85 -then use carefully a fine flame gas torch around the nipple continually trying to undo it with a well fitting small ring spanner -it doesn't normally need much of this process to get movement -sometimes even initially tightening the nipple slightly once heated can help.
Just needs a good degree of feel & care.
good luck
graham tompkins
Graham
chaser
GeoffB said:You could also try to loan a induction heater, my local garage has one and you select the coil to suit the size of fixing and heat up just the fixing. Since he's had it he has not snapped a fixing. May be able to hire these now. In addition I tend to use a deep socket with T handle as you rotate the bleed nipple around its access. Using a spanner can put an axial load on. But as Vitesse above says just needs lots of feel and care it can be done
good luck
This ^^^^^^. A gas flame could damage the painted caliper, if that`s what you have. A `specialist` broke 7 out of 8 on my last car costing me 4 new calipers at around £500 each ...... not happy.
I now replace my bleed nipples with stainless items to reduce the risk.
Dekker
Those induction heaters are the way to go.
I had one break and I saved the caliper by finding a shop with spark erosion equipment and for a special after hours price, he drilled and removed the broken stub.
Indeed - I asked a PC to do a report on my car and this included "caliper bleed nipples frozen - requires specialist skills".T911UK said:A new "specialist" is all that is required.
Er. . . ok I'll take it to one.
Mark,Mark Elder said:Indeed - I asked a PC to do a report on my car and this included "caliper bleed nipples frozen - requires specialist skills".T911UK said:A new "specialist" is all that is required.
Are you saying that your local PC could not undertake the work?
Ray
Hi Ray - no, I'm just saying that my indy would have just got on and solved what is a normal expected part of bleeding brakes on a classic car without even mentioning it to me. PCs (or some of them) say they want to attract classic owners back so I'd expect them to take in their stride the freeing off of a bleed nipple.Ray said:Mark,Mark Elder said:Indeed - I asked a PC to do a report on my car and this included "caliper bleed nipples frozen - requires specialist skills".T911UK said:A new "specialist" is all that is required.
Ray
The full story is that I decided to give a PCs a second chance (having had a bad experience just after acquiring my 993 12 years ago) mainly because my indy was concerned about me driving as far as him with a particular issue (the PC is much closer). I was also tempted by the "Classic register" (which comes with an oil service). So I booked it in for the up coming service (24k) including brake fluid change and I was given a "free health check". I honestly found this very useful, but the "requires specialist skills" on something basic made me laugh and reminded me that my indy is 70 years old and the PC mechanic looks about same age as my car!
So far the rest of the experience of the PC has been good* and I've already booked it in for further work.
* Except being "kept up to date". After initial, very fast, diagnosis I was then left in dark and had to pester them when promised return phone calls didn't emerge (e.g. I twice was promised calls back "first thing tomorrow" but had to call them at 5pm to get an update - which I suspect had been available for a while but had not been passed on).
les richards
