Front wing/scuttle seals 911
- Thread starter Bcwjma15
bernard tester
Hi you can change the seal without taking the wing off! if you loosen the bolts take the top two out, only use Porsche seals and just take your time. Berny.
bernard tester
You will find that after all the years the wings will be stuck on quite tight and you will need a bar to pry them out a bit perhaps I made it sound to easy but I have done lots over the years. Just take your time and use something to protect the paintwork. regards Berny.
