chrisg
Evening all !
As my winter job this year, I'm replacing the cam & balance belts and whilst in there the front crankshaft oil seal which has been leaking for some time.
I'm now at the 'bottom' of the job, ie nearly finished dismantling before starting to put back together - having carefully photographed, marked and noted just about everything !
Question is, has anyone safely removed the front crankshaft oil seal ? Without getting brutal with a screwdriver, I'm struggling to work out how to remove it.
The rear crankshaft seal is very straightforward as there is a notch in the rear engine case to prise it out with a screwdriver.
Any suggestions or recommendations gratefully received !
Yours
Chris
Yours
Chris
