chrismanchr
Ive had a small leak on the plastic elbow fitting off the waterpump since I bought the car
I thought the plastic elbow was probably warped due to over tightening and I bought a new plastic elbow and new seal ,on taking it apart ,the plastic elbow was badly warped causing the leak ,the allenkey bolts were very dodgy and need replacing asap ,but the original seal was completely inadequate ,and I found a much fatter ,tougher rubber seal in my spares box
as far as bleeding the coolant ,I used my compressor and a vacumn brake bleeding gun it sucked all the air out through the bleed thread ,and as soon as I started it coolant came out ,I squeezed the hoses etc but it looks like the vac gun got most of the air in one go ,the guns reservoir was full of coolant , the coolant that was in the car when I bought it was a very weak mixture due to topping up with water and the leak ,now the coolant is very blue [
