eratic idle
anyone any idea why the idle should be dropping down to 3/400 on occassions, usually when the car warms up a bit? I keep stalling, doesn' t look good!
The airflow meter is known to be reponsible for this symptoms when its magnetic track gets worn/corroded with age.
You might try to clean the track by removing the plastic cap of the unit, which means removing the joint and then the screws, although good results are not always guaranteed.
I had this problem a couple of times but good B-road thrashings have always cured it ... [:D]
Have a look at your spark plugs too.
My Cab did this until recently. It was a combination of varnish on the throttle butterfly and a dirty idle stabilisation valve.
Both can be cleaned with carb cleaner (the stabilisation valve sits under the inlet manifold between 1 and 2 inlets - on an S2 at least).
As well as stabilising the idle nicely it solved an intermittent hot-start problem.
I still have a shunt sensation at constant 30mph in 3rd that could be the air flow meter though, but that' s been diagnosed as drive shaft joints as well [&:]
thanks Fen
it actually seems to have cleared itself - but I' ll get in there and clean everything anyway!
