Enough already!!
- Thread starter liam996
thirteeneast
take it back.
Best of luck Liam.
thirteeneast
kasspa
Sorry to hear of your further woes..... I would've thought that they had a duty to look at car asap given what you'd been charged....
If all else fails & you're really stuck, you could speak to Dove House in Rushden as they now have their own service dept but doesnt mean they can fit you in..... & would they want to inherit someone elses problem!
atb
Paul
thirteeneast
Every customer that goes there will want to know all about it.
There just trying to fob you off because they don't want it back.
Did you have to wait 2 weeks when you first took it there?.
And question your bill again "as to what did they fix?"
All the best.
steveoz32
Check fuel delivery
-Leave fuel and pressure to settle for several hours, turn the key, check the pump primes for two seconds or more
-Remove spare wheel, trim and carpet under hood near fuel tank (under the battery tray) crank and see if you can here the pump whining
-Check fuel relay, bridge top and bottom pins with a fused lead or fuse wire for several seconds to check pressure and delivery
-Crack open bolt on end of fuel rail by 1 turn, have someone turn it over, check fuel is there (don't open too much or you will have a geiser!)
-Check you have sufficient fuel (silly one but check this, do a search for fuel sender unit and my name and you will find a diagram indicating the issues on 996 with the float being obstructed by the fuel lines)
-Check fuel lines if you have a delivery issue and the pump is ok, remove battery and tray, large collar and pull the lines off and unit out
-Test fuel cap is venting, remove cap when problem is experienced
-Have duty on injectors tested, and perhaps run cleaner through them if a fuel delivery issue
-Change fuel filter
Check Ignition
-Check barrel is opperational (volt meter on a switch to the ignition feed)
-Check ignition relay, some more info I posted up on here and 911uk http://911uk.com/viewtopic.php?t=61940
-Check coils are opperational, either diagnostic or remove fuel relay and bridge coils to check for spark (harsh way but it works)
-Remove and inspect plugs
-Test Crank sensor (diagnostic readout of realtime RPM required on this one really when the vehicle is showing symptoms)
-Have CPS's inspected / tested (although would likely start and cause rough running or loss of power)
Other than that the next things would be more serious inspections within the actual block, but I seriously doubt it's anything serious, just a small problem that is difficult to identify.
That's all I can think of for now - good luck.
Cheers,
Steve
steveoz32
That is a strange one, and from reading the symptoms and the amount you have had replaced it sounds to me like you may have been 'unlucky' in that another fault was brewing and or adding to your existing issue (that would be my suggestion if the loom and ECU / lambda was replaced correctly).
I'd suggest in that case taking it back as you paid a fair amount for it to be rectified in the first place and having it inspected (I would insist without cost for checking the original work), or getting an inspection on the original work by a third party.
If this is ruled out then it could be something like the CPS or similar that was compounding the issue.
It's extremely strange that the wire on the lambda touched the manifold an melted, that sounds to me like the lambda was replaced with either an aftermarket one or a generic four wire one with a longer loom allowing it to move around. Do you have any history of anything like that being replaced before? Was anything else changed at that time? It could help rule out other components if it was fairly recent.
Cheers,
liam996
I think I would be patient and get it to an OPC, possibly on your indie's expence. If they don't have the knowledge locally they certainly have the network to sort it out. I hope...
It seems that so many of the faults that have been tried and tested wouldn't stop the car from starting, just give a fault message in the ECU. But it certainly seems like a complicated issue.
Good luck and hang in there, you're gonna love the car once you get it sorted. [
thirteeneast
liam996
Just wonder it you've got Mr.Streather's 996 book? There's quite a few possibillities under the fault finding section that's not mentioned in your other tread. I guess a lot of people have that book so I didn't bother to quote any of it but if you don't I can list some of it for you.
