Any suggestions on a puzzling engine fault just started with 1984 2.0 litre 924, resulting in a Relay home?
Last Friday :-
Engine wouldn't fire on first turn from cold ( normally good).
Fired, just, and then caught on second turn.
Run happily for 5 miles, then the engine slowly dies ( like fuel starvation, though tank is half-full) and we roll to a halt. Won't start.
Change the fuel pump relay( always carry spare), check fuse, but no joy. Check getting a spark. OK, but...
While waiting for the AA, try again .
Engine starts, but dies after a few seconds. Wait for ten minutes and same thing happens - it fires, sounds healthy and then dies after a few seconds.
Finally relayed to local garage( closed) in village. After Relay left, decide to try again.
A healthy start, healthy running.. ..decide to dash for home half a mile away and make it OK. Turn off. Try starting again. No joy.
Previously - One instance of non-starting traced to broken, not blown, fuse. Occasional problems on re-starting hot recently - like one cylinder catching and others taking time to join in.
Fuel pump(s) is old, could be original ( 94k miles), but sounds as if it's working.
My local garage will do the job, but it would be good to have some pointers for components to test first. It sounds more like a fuel supply problem. I have checked previous posts, but problems tend to be with cold starting rather than warm dying. The Relay driver said his father had a 911 with similar problems, traced ( after expensive investigations) to a loose wire. How reassuring! Any ideas which wire I might waggle??!!
All suggestions gratefully received. I must positively fix the fault now before attempting any journey more than half a mile, just in case it all goes dead again in the middle of nowhere...............
Last Friday :-
