Hi,
My 1986 944 turbo had its engine cut out suddenly today. Over the course of the next 10 minutes I found some times it would restart immediately, then die 3 seconds later, other times it would run 20 seconds then die.
After leaving the engine switched off for 10 minutes I fitted a new DME relay that i carry. It restarted then cut out once. I restarted a second time on the new DME relay and it ran fine until i got home twenty minutes later. I then switched it off.
When running its perfect.
Any guidance would be very much appreciated on where to start.
